175/60 x 13 tyres
175/60 x 13 tyres
Postby Stuart » Wed Mar 23, 2011 9:02 am
Anyone out there running 175/60 x 13 tyres on their mk3's ?
I ran a set on my mk2 many years ago. I'm looking for more comfort these days, also with a fairly lofty ride-height they will give both good ground-clearance and hopefully not catch on the flat top part of the arch.
I'd have preferred some 185/55's, but it looks like this size is going out of fashion just like the 165/60 has done.
I have CF1's on another car, and find them good, they do a 175/60 x 13 as well
http://www.toyo.co.uk/tire/pattern/id/4627
Re: 175/60 x 13 tyres
Postby Hans Efde » Wed Mar 23, 2011 11:59 am
I had these on my first Midas. They chafed my wheel arches under heavy bouncing. They are made of soft rubber, resulting in a softer ride but less steering precision. Also they wear out quicker than a Good Year or a Bridgestone.
Postby Stuart » Wed Mar 23, 2011 12:35 pm
Interesting, thanks Hans. As you say they are pretty soft, they're wearing pretty quickly on the front of my Micra.
I may give them a try if they're still available when the car needs tyres, carefull positioning of the front coilovers should stop any rubbing issues and I guess running some of the OE spec wheels with a 130 mm C-dimension will also give more top arch clearance being that extra 15 mm inset into the arch.
Postby Stuart » Tue Apr 05, 2011 6:44 pm
My old A-001 Yokohamas, the best tyres I've ever had by a very large margin
Return to Miscellaneous
