Wiring Loom Help Required
Postby PeteH » Tue Feb 17, 2009 8:33 pm
Hi
Does anybody recognize this part from the wiring loom of a Metro GTi which I am trying to place in my 2+2 Coupe? If so, what is it and where does it fit?!! :?
Thanks
Pete
PeteH
Re: Wiring Loom Help Required
Postby Stuart » Tue Feb 17, 2009 8:46 pm
Is it a throttle position sensor?
Postby PeteH » Tue Feb 17, 2009 9:51 pm
Panic over - went through the wiring diagrams and it connects to the ignition switch!!! :D
PeteH
Postby manifold » Tue Feb 17, 2009 10:09 pm
looks suspiciously like the bottom of an ignition barrel to me. I could be wrong but they look like the 2 brown live wires.
Postby PeteH » Tue Feb 17, 2009 11:23 pm
Thanks for your replies - it is the ignition connection from the base of the key barrel!
Fast forward to the next problem!
Pete
PeteH
Postby Rich » Thu Feb 19, 2009 12:34 am
PeteH wrote:Thanks for your replies - it is the ignition connection from the base of the key barrel!
Pete
Frequently seen hanging from under the steering wheel being actuated with a screwdriver.........
Damn, I'm glad I moved out of Bradford..
Postby PeteH » Thu Feb 19, 2009 11:56 pm
yes, those damn screwdrivers are everywhere, lock up your Midas.
PeteH
Return to Mk 4 Cortez
