Dear all.
I am going on a 'trip' for a couple of weeks. Server will be running in my absence, but if it should fail, I won't be able to sort it out until I return. Hopefully it won't be shut down. It hasn't been off for the last month or so (since the hack).
Rich, If you could do a weekly back up of the forum (more would be even better), taking the sql file back up to your PC that would be great. Its under maintenance. Make sure you 'select all' files.
