The car is currently up on axle stands as I've had to remove the fuel tank for modifying properly before it will ever see an MOT again (it was leaking). In doing so I'd had to depressurise the hydragas and realised that in an ideal world I wouldn't have to repressurise the blasted things as I've recently bought some rear coil over units.
What I need are some brackets for the lower mounting points and some springs (I'll put up a separate post for these), finances are tight so the car won't be seeing an MOT this month.
