Mk3 Coupe Rear Side Window Seals
Postby mikeeskriett » Sat Oct 01, 2011 8:26 am
I may have some of Charlies Mk3 Coupe rear side glass rubber, I will confirm next week once I've had a look as it's in the bottom of a box of Metro bits I got from Rose. If someone can let me know the correct length I can make up some sets. If it's the right stuff I will make them up for £15 a pair plus P&P on the strict understanding all the proceeds go to Rose's ladies who do lunch pot as the extra beer tokens will be handy for her.
Mike
mikeeskriett
Re: Mk3 Coupe Rear Side Window Seals
Postby Stuart » Sat Oct 01, 2011 10:26 am
I've measured mine at 62.5 inches, so 64 inches to leave a little spare? we'll see what others make it.
Postby Alan D. » Sat Oct 01, 2011 12:13 pm
Me too please, two sets if possible, I'm greedy
I'll measure up when I go to the garages.
I'll send a cheque next week. Made out to whom?
Postby DavidL » Sat Oct 01, 2011 12:26 pm
Mine are currently bonded in, but there's a strip of black insulating tape stuff along the edge of the glass, presumably to stop degradation due to UV.
Would I be better to replace the glass with rubber seals, or just leave well alone? As far as I know they're not leaking, but for all I know they could be on the point of falling out.
Postby Stuart » Sat Oct 01, 2011 7:47 pm
The bonded in ones will be larger so to go to rubber seals you'll need the smaller glass.
Postby DavidL » Sat Oct 01, 2011 8:37 pm
Stuart wrote:The bonded in ones will be larger so to go to rubber seals you'll need the smaller glass.
Didn't even think of that. I'd thought the rubber seal used was a "Z" sort of section for some reason, with the glass larger than the aperture - a bit like this:
side window.JPG (4.8 KiB) Viewed 10162 times
Postby Stuart » Sat Oct 01, 2011 8:40 pm
Yes it is like that, however I believe the bonded in version is larger.
Postby DavidL » Sat Oct 01, 2011 9:23 pm
Stuart wrote:Yes it is like that, however I believe the bonded in version is larger.
Which came first? Did the change happen when Midas manufacture changed hands?
Postby Stuart » Sat Oct 01, 2011 9:27 pm
The early cars had rubber seals, later ones were bonded, and the car was only ever made by Harold's company.
Postby DavidL » Sun Oct 02, 2011 8:41 am
Ah, OK, thanks. Didn't realise (or had forgotten) that Pastiche/GTM hadn't produced any Coupes.
Users browsing this forum: Google [Bot] and 6 guests
