Carb vent?
Carb vent?
Postby Geoff Butcher » Tue Mar 03, 2009 5:24 pm
While poking about under my bonnet I found a bit of hose attached to the right side of the carb which had been dangling on the manifold. I can't find anywhere for the loose end to go, so am I right in thinking it's just a breather? In which case I might just as well pull it off and reduce the clutter a bit.
Re: Carb vent?
Postby manifold » Tue Mar 03, 2009 6:50 pm
I think I'd be wanting to steer that carb vent onto a hose well away from a hot exhaust manifold.....
I have my leading away down the back of the subframe.
