manifold wrote:Ok. With this eBay item for megasquirt it will work with a series engines. You will need to source a trigger wheel (or make your own) vr sensor and bracket, ford solid state coil and an edis module, however the megasquirt can be reconfigured to fire direct to coil (ie without edis module) unlike the mega jolt which needs the edis module. In addition you will need to get the plugs to connect coil etcI have a curve to suit the a series to get you started.
This item is good as it even includes the relay board which makes it dead easy to wire in.
Thanks David, I'll keep watching it, might go for it if it doesn't go up too much. It's also close enough for me to collect for less than his postage and packing charges would cost...
