Back in the garage though, it has been a frustrating time. Once more the ugly spectre of seized rusty bolts has raised its evil head and I spent the best part of 3 hours trying to remove 3 bolts. No, REALLY. They were three of the four bolts through the bottom of the dash that hold the brackets for the heater. What should have been a simple 5 minute job with two 7/16" spanners was at first thwarted by the fact that the top of the bolts (and washers) had rusted together to form an amorphous blob of what once was metal. And of course trying to undo the nut just turned the blobs. Because of the angle they were at, I could not get the Dremel in there to cut it off flush. So I spent WAY too long cutting little bits of the bolt heads off before eventually chiselling the rest off. Then the Dremel died. The switch has killed itself. For the price of a new switch I can almost get a new Dremel; I will probably do that then sell the old one on ebay as "Spares or Repair". I really can't be bothered to try to repair it. Plus it was starting to sound a bit rough...
I dug out the engine front plate from the spares box as I remembered it REALLY needed a clean. Several years of sitting about in a box meant it was still covered in bits of old gasket sealant, some remains of the gaskets and a large amount of surface rust. I gave it a going over first with the scraper to get the gasket & sealant off, then with the wire brush attachment to remove the rust. I also cleaned the threads for the timing cover as they were full of all sorts of crud.
Finally I spent a bit of time painting the rear beam and a few brackets with Hammerite, as well as giving the brake backplates another spray coating. Note to self: when cleaning your brush with white spirit, do not drip it on the graze on your hand. Ow...
Poxy heater bracket bolts: 3 out, one to go... (I had already thrown the other one away!!)
Beam & brackets in the process of drying.
Brake backplates after a second coat
Engine front plate after a damn good clean
