Haven't done that much recently (been working hard and also enjoying the nice weather); managed to find a new-old stock Allegro headlight on eBay although I have also found someone who is selling new-old stock Halogen Bedford Rascal Lights. They are the same size so I may invest in a couple of them when funds allow.
I have been thinking about the ridiculous bolts that held in the pedalbox. These had been cut and ground down to within an inch of their lives and were a nightmare to undo/remove as they sit just under the front bulkhead/crossmember. What was needed here was a plate with captive bolts. So I dug around the bits box and found a broken brake disc shield. Some, hacksawing, hammering and bit of vice work had a plate bent into shape. I took it over to Mike's and welded the bolts in place. It's not pretty, but once again no-one's going to see it so I gave it a coat of paint along with all the other bits that needed it.
I have finally got round to removing the bracket for the steering column as well. This was no fun as the bolts had been sat below a leaking windscreen for a number of years and had turned into rusty amorphous blobs. I managed to undo the nut on one whereas the other required more brutal methods, namely Molegrips and a hammer (NOT a Dremel for once!). Everything will be cleaned up and reconditioned. You'll be pleased to know I have put the bolts in the bin.
Finally the petrol tank: Having failed to find a used tank at a realistic price, I am looking to have mine repaired. I am led to believe there is a place fairly nearby who can weld tank seams, so this will be on my list of things to try first. I also removed the sender unit, as I was sure it was probably past its best. Amazingly, it wasn't as bad as I'd expected, but it was still pretty grotty, especially the electrical contacts. Time for a new one.
New-old stock Allegro headlight; a snip at £9.
First coat of paint for more suspension parts & brackets
Steering column bracket, spacers and bolts. Now cleaned and ready to be re-used.
Pedalbox captive bolt plate - made from an old disc shield!
Sender unit removed from tank. Doesn't look pretty...
