Mark 2 midas project...
Postby Midasmatt » Mon May 04, 2009 10:23 pm
Right... Hi all :)
Got the midas today
started on it straight away...
Jobs done so far:
-Oil and filter change
-Battery fitted
-Ignition barrell and wiring fitted and all working
-Carbs removed, stripped down and cleaned, reassembled and put back on the car.
- Engine turns over ont he starter but has no spark to any of the leads, wiring problem as a certain part of the wiring loom gfot very hot when tryin to start it
Jobs to do:
-Get engine running
- strip down and get all suspension and brakes working properly
- Interior needs tidying up, carpets, reupholster seas ect...
- some bodywork stuff to do where there are chips and cracks in paint ect, some re fibreglassing to do...
aaand then stick it in for an mot at work and if it passes... get insured and drive it aboout while the mini gets an enigne overhaul... i hope
pics tomorrow as i forgot today.. was toooo busy
WhEn In DoUbT gIvE iT a ClOuT!
If YoU dOnT hAvE a SpAnNeR, hIt It WiTh A hAmMeR!
Midasmatt
Re: Mark 2 midas project...
Postby Rich » Mon May 04, 2009 10:32 pm
Sounds like you've had a busy day Matt, keep us updated.
Postby Midasmatt » Wed May 06, 2009 11:26 pm
WHOOOOOOO got it running
did the timing, put some fresh fuel in it and she fired up got a huge fuel leak from a seal on the carb that will be easily sorted:)
lots of black smoke at first haha but it runs!!!! whoop
Midasmatt
