by manifold » Fri Apr 30, 2010 5:44 pm
Here you go Johnny, dash photo as requested.
I seem to have misplaced one of the tails for the back. I'm sure its somewhere in the garage, as it has never been moved from there. If I find it I can put it in the post. You should be able to modify one of the metro ones at a pinch though. I can give you a couple of them too.
On a separate note I also found the speedo cable which converts to A series cable (different fixing than metro). You can have that as well if you want it. Also found a special filler piece for front of dash (bespoke Midas part).
- IMG_0191.JPG (1.41 MiB) Viewed 9471 times
