As I have now handed over my Midas MK3 Gold Coupe to the new owner I have lots of parts for sale that I have gathered over the last 6 years. Some of the parts are Midas specific others are standard Metro. The items are listed below if anybody is interested in anything please let me know before I put them on Ebay. I have pictures of most of these items if needed and most are new.
Thanks, Russell
Gold rear bumper in burgundy
Handbrake cables x 2 modified by Speedy Cables.
Hrdrolastic pump in excellent condition
Rear radius arms
Suspension globe
Clutch master cylinder
Rev counter
Mg Metro Clocks
Borg and Beck clutch
Indicators
Anti run on valve
Brake master cylinder
Ball joint
Steering coupling
Top radiator hose mk2 rad
Inner CV joint
Front subframe mountings
Front disks with drive flanges
Verto clutch kit
water pump
Clutch slave cylinder
Temperature sensor
Borg and Beck clutch arm
Oil pressure switch
SU carb dashpot damper
Lower suspension arm
Front wheel bearing
Outer CV joints
fuel sender unit
Fuel pump
Bottom radiator hose
Rear wheel bearing
Ignition lock with 2 keys
Suspension knuckle joint
Flywheel bolt both types
Loads of engine mountings
