KAD Twin Cam A series engine
Postby Midaspeter » Fri Sep 04, 2009 9:54 pm
This is advertised on http://www.racecarsdirect.com:
Description:
1300cc A series race engine 180bhp. A+ block, Steel crank and rods, KAD twin cam head, Weber fuel injection and management system, complete with wiring loom and exhaust. Might consider splitting if enough interest in parts.
http://www.racecarsdirect.com/listing/2 ... ngine.html
Greetz,
Peter
Midaspeter
Re: KAD Twin Cam A series engine
Postby Rich » Fri Sep 04, 2009 10:26 pm
...... dribble........ engine porn......
Postby manifold » Sat Sep 05, 2009 9:36 am
Thats very interesting KAD engine as its for inline use. Ie MG Midget or Similar. Looks like it has a bespoke flywheel and gearbox mounting plate so it might even be for some other car.
You can also tell because it has a sump plate and is dry sumped (no oil pump driven from jack shaft ie a blank cam))
This one uses weber alpha management. I'm not too happy it doesnt have a crank damper though. The A series needs all the damping it can get, especially with the long cam KAD head.
Return to eBay links
