mk3 silicone hoses
For those wanting to have silicone hoses on the Mk3....heres an idea.
Make your own hoses using these self sealing connectors.
http://www.revotec.com/catalogue_SelfSeal.asp?offset=4
If you have a mk3 you will know it has an extra connection in the bottom pipe same as the metro for the header tank, so you cant use the a series mini kit.
Mk4's have the option of off the shelf mk3 metro/R100 kits. If someone has seen a silicone kit 'off the shelf' for a mk1/2 metro I'm all ears.
