Along comes Megajolt2
http://www.autosportlabs.net/Megajolt2
Megajolt/2
Summary
Megajolt/2 is a Programmable Crank Fired ignition system designed as a single-unit replacement to the MJLJ + EDIS ignition system.
Capabilities
4,6 or 8 cylinders in wasted spark mode
4 cylinders in Coil on Plug mode (using standard coil-on-plug modules)
10K RPM capable
0.1 degree timing resolution
Features
Dual VR Sensor input
Crank Sensor + Cam Angle Sensor input
4 on-board coil drivers
Soft and hard rev limit
Designed to work with commodity OEM sensors and coil packs
Initial support for 36-1 trigger wheel; other trigger wheel configurations to follow
up to 16x16 ignition map with linear interpolation
Dual, on the fly switchable ignition map support
4 User defined digital outputs
3 analog input channels
TPS, Temperature and Aux
Ignition advance correction for Temperature and Aux
Provision for on-board MAP sensor
On-board expansion for knock sensor module
32 bit 48Mz ARM processor
USB programming interface
Megajolt/2
Summary
Capabilities
10K RPM capable
Features
