Cutting rear subframe for undertray fitting
Postby Rich » Thu Sep 15, 2011 12:25 pm
Apart from removing the hydrolastic spheres and side plates do I need to trim anything off the rest of the standard subframe in order to fit the rear undertray. Although I haven't got an undertray as yet I have got the tank and everything else off and I might as well run the cutter over it now rather than take it all apart again when I do get a tray.
Re: Cutting rear subframe for undertray fitting
Postby Stuart » Thu Sep 15, 2011 12:37 pm
I'm pretty sure you also need to cut off the most rearwards bottom bit too.
npp 009.jpg (65.25 KiB) Viewed 8336 times
Postby Rich » Thu Sep 15, 2011 12:45 pm
I can't find a reference to it in the build manual, or any drawings.
Postby Stuart » Thu Sep 15, 2011 2:13 pm
It's in the coupe build manual, 11 inches back from the front bottom edge of the subframe.
Postby Rich » Thu Sep 15, 2011 3:28 pm
Stuart wrote:It's in the coupe build manual, 11 inches back from the front bottom edge of the subframe.
Cool, I can cope with that. Thanks Stuart!
Postby Rich » Thu Sep 15, 2011 5:11 pm
10 minutes with a plasma cutter later, there's no going back now.......
Postby Alan D. » Thu Sep 15, 2011 6:05 pm
My version of the cut, get rid of the dead meat!!!
Picture 3.JPG (932.88 KiB) Viewed 8320 times
Postby Rich » Thu Sep 15, 2011 6:43 pm
It's not far off that Alan, but I've retained the top edge and rear mounting point. To be any more radical would mean dropping the frame off the car and I'm really not in the mood to do that right now.
Return to Mk 3 Convertible
