Wiper Sweep ?
Wiper Sweep ?
Postby AllanH » Sun Nov 04, 2012 9:10 pm
Am currently completeing (reworking) a Mk 3 convertible recently bought.
In having to rework the harness loom necessiatig getting the wiper assembly out, determined that the wiper motor was u/s. Got a complete new wiper assemblywith motor OK (all works fine) but have noted that the previous (Midas) owner has reworked the offside (driver's side) of the originall fitted wiper linkage; lengthening the offside crank arm by about 6/7mm (byinserting a filler piece). The effect will be to reduce the sweep of the n/s wiper.
I haven't found anything in the Midas build manual to recommend/instruct doing this - so wonder about the need for this. As it wasn't a small job to do, Presumably the previous owner made some judgement about the sweep with the standard crank arm length resulting in too wide an arc of wiper sweep.
Any knowledge/comments ?
Any info/advice appreciated.
cheers
Allan
AllanH
Re: Wiper Sweep ?
Postby Hans Efde » Sun Nov 04, 2012 11:47 pm
It is mentioned in an early MOC magazine to prevent the wiper running over the windscreen rubber.
Re: Wiper Sweep ?
Postby AllanH » Tue Nov 06, 2012 7:30 pm
Thanks Hans, that's appreciated. I'll modify the crank arm.
best regards
Allan
AllanH
Return to Mk 3 Convertible
