how do you remove a driveshaft?
Re: how do you remove a driveshaft?
Postby Hans Efde » Tue May 22, 2012 4:11 pm
This afternoon I got the driveshafts out. It is not possible by removing the balls of the inner CV. The cage is still too big.
So out came the persuasion tools.
With just 2 bangs the outer CV snapped loose and I could remove the drive shaft.
Then on the other side also 2 bangs and also the outer CV came loose. Cut the boot loose, disconnect the hub and result:
So coming Friday I hope to get the subframe out and start cleaning the engine bay.
Return to Mk 3 Convertible
