headlight/mainbeams
Re: headlight/mainbeams
Postby Rich » Fri Nov 20, 2015 8:02 pm
kelvink wrote:Have you had a good look at the earthing? It sounds a bit to me like current is trying to find alternate routes to earth.
It does indeed, there should be earthing points at either side of the engine bay. I'm assuming you have a Gold? The main headlights are standard 7" items and you'll get a useful performance increase by getting rid of the sealed beam units, Wipac Quadoptics are always a safe bet.
Postby billybob » Mon Nov 23, 2015 8:55 am
well, it turned out to be much more simple....
changed the bulb in the headlight unit (very glad it wasn't a sealed beam unit) and everything was fine. Except for the fact that the main beam light below stopped working, changed the bulb in that unit and it still doesn't work!
I must have knocked a wire loose but at least it wasn't an electrical ghost that are sometimes impossible to find!
keep on trucking
billybob
Return to Mk 3 Convertible
