Stuart wrote:The Rover 200 disc is going to need some machining to fit. I'm only half interested in this as I actually prefer to have drums on the rear.
A quick look for a disc with a big enough centre hole found these http://www.ebay.co.uk/itm/Rear-Brake-Di ... 416b455b45
I guess there must be discs out there that have the required 65mm ish hole (can someone else double check that on a rear hub of theirs please?)
This ebay seller has all the dimensions of discs http://stores.ebay.co.uk/gsfcarparts/Di ... m14&_pgn=8
Oh and I just realised the disc I tried must have been a Micra disc as I see the Vauxhall disc have a large centre hole.
Edit This looks about the best option perhaps http://www.ebay.co.uk/itm/Rear-Brake-Di ... 5895152de2
Same seller but cheaperhttp://www.ebay.co.uk/itm/Rear-Brake-Di ... 4168bee8dc
and slightly cheaper http://www.ebay.co.uk/itm/Eicher-Rear-B ... 0691952214?
pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AVW%7CModel%3APolo&hash=item43ae972e56
Stuart wrote:As Alan says don't forget the calliper carrier
David L wrote:I've been watching this thread with much interest, as it's something I'd be keen to do as well.
Something that occurred to me, which I haven't seen mentioned yet, is matching the radial depth of the disc pads with the swept area of the disc on the donor car, especially since you're using discs and calipers from different vehicles. Is this actually important, if the pads are smaller than the disc's donor? I'm thinking about it from the point of view of the unswept area of the disc eventually developing surface rust, rather than unmatched braking force.
