http://bremboaftermarket.com/En/Car_Dis ... ster=21348
Slightly annoyingly the Brembo site doesn't seem to list MGF discs.
Rover 200
Part Number : DSK2036
| Brake Disc Thickness [mm]: 10
| Brake Disc Type: Solid
| Centering Diameter [mm]: 61,1
| Diameter [mm]: 239
| Height [mm]: 48,1
| Hole Arrangement / Number: 04, 08
| Minimum Thickness [mm]: 8
| Pitch Circle [mm]: 100
| Supplementary Article/Supplementary Info 2: Without wheel hub
| Supplementary Article/Supplementary Info 2: Without wheel studs
| Weight [kg]: 3,2
| Fitting Position: Rear
PART NUMBER: DSK257
Make : Rover (MG)
Model/Engine Siz : MGF 1.6i
Model Name : MGF
Year : 2/2000
Fuel Type : Petrol
Disc Type : Solid
Disc Diameter : 240.0mm
Disc Thickness : 10.0mm
Min Thickness : 8.0mm
Disc Overall Height : 43.0mm
Centering Diameter : 66.0mm
Disc Mounting : 4
Front/Rear : Rear
Disc Quantity : 2
