Alan D. wrote:[quoteBy calculation, the rate of the original Midas rear springs on my Mk3 comes out at 107lb/inch.]
Done all of that, started at 140lb springs, then 120's, then 90's and am now running 75lbs/inch and they still feel too hard, but I' am waiting till I finish my front coilover conversion. The most important thing to remember on the rear, is the top stud fixing will be too short, due to the thicker fibreglass! Steel is only 3mm thick as opposed to fibreglass which can be 10-15mm thick, which means you cannot get two modern rubber bushes on the stud fixing, keep your old bushes if you have them they are thinner!
Another Midas owner up here in the frozen north has just purchased new rear coilovers from Gaz and they have fitted the wrong valves, so the shocker is too hard and won't move, they have still made the top stud too short, despite me telling them to alter their spec for Midas's! The steel bodies on the Gaz coilovers rust in no-time! Protech have a two stage valve.
https://lh3.googleusercontent.com/_oXTm ... C_0040.JPGhttps://lh3.googleusercontent.com/_oXTm ... C_0039.JPGTheses are obviously front Protech's on a Mk 3 Midas!
Alan[/quote]
Those pics you've put up are pretty much identical to the design I've scribbled down. I'm going to be lazy now and do nothing till I know if it works...basically you can be my guinea pig
