faceofdoh wrote:If only it was thirty years ago - I believe the Hillman Imp engine could be fitted onto a Mini gearbox, and it responded well to tuning, ISTR. As long as the owner believed in maintenance!
Having driven one of the first Alfasuds, I understand why Gordon Murray did it (did that car ever get used on the road?)
Seriously though, I'm interested in this too, and also reluctant to change the car's body in any way, but without the time and money to play around with possible donor engines.
Oh, and another thing occurred to me this morning. The original ADO15 Mini had the engine sited ports forward, but when it was turned so the ports faced rearwards, and an additional gear stage added to reverse the gearbox motion, this was reported to have induced a considerable power loss.
So, what might be involved in modifying an A series engine to run backwards, and remove the additional gear stage?
Camshaft, yes, I know; water pump, oil pump. If a non-distributor ignition system is used, that's one less thing to worry about. What else would be needed, and am I daft to even think about it?
wolfie wrote:My old man told me you used to be able to get bellhousings years ago to fit the ford crossflow as well
