Rich wrote:Hi Wolfie,
Megajolt comes with default maps in both NA and Turbo that will get you up and running, there is a library of maps on the support forum though your best bet is to get it set up properly for your installation. The support forum and online instructions are excellent and Brent who owns the company will always go that little extra to help out a customer.
I fitted MegaJolt when I rebuilt my Convertible, I wouldn't say it is difficult but it certainly is fiddly and you need to work slowly and methodically, particularly if your loom has already been hacked about over the years. The results are definitely worth it. Having used all second hand components in mine (apart from the ECU) I would suggest at least buying the connectors new for the EDIS, coil units and crank sensor, they are a pain to take apart and solder new wires to reliably.
There are pictures somewhere on the forum of how I fitted both my trigger wheel and sensor bracket. I used the standard wheel from Trigger Wheels rather than the A series setup. Apart from losing the wheel once and a cracked solder joint at the sensor, both my fault, mine has worked perfectly well.
manifold wrote:£400! for just sparks...bloody hell! I'm in the wrong job.
