Page 1 of 3
Window runner
Posted:
Thu May 03, 2012 2:24 pm
I might have the wrong term here but I mean the bit that clips to the bottom of the wind-up window on the old two piece windows.
Are there any sources for a suitable replacement? There are no metros in the local yard (who'd have thought you could ever say that?) I have a vague recollection that someone had mentioned a suitable substitute, possibly Land Rover?
Re: Window runner
Posted:
Thu May 03, 2012 2:36 pm
yes you could use a wind up landrovers. Cut it in 2 and you have one for each side
Re: Window runner
Posted:
Thu May 03, 2012 9:24 pm
by mikeeskriett
Mine are Land Rover Defender 90 jobbies and they work a treat, you can get them on fleabay cheaply along with the rubber liners which are normally a bit crusty on the originals.
Re: Window runner
Posted:
Thu May 03, 2012 10:34 pm
Thank you both, that gives me something to work with.
Re: Window runner
Posted:
Thu May 10, 2012 10:10 pm
by Maphet
By way of returning a favour, there is an Austin Metro in my local breakers. Unfortunately they only let you in that bit of the yard on a Saturday and I will not be able to get there for at least the next two without risking divorce. However, if you are not in any hurry and can give me a photo of the bit you want then I'd be delighted to pull it off and post it on...
Matt
Re: Window runner
Posted:
Thu May 10, 2012 11:48 pm
Maphet wrote:By way of returning a favour, there is an Austin Metro in my local breakers. Unfortunately they only let you in that bit of the yard on a Saturday and I will not be able to get there for at least the next two without risking divorce. However, if you are not in any hurry and can give me a photo of the bit you want then I'd be delighted to pull it off and post it on...
Matt
Hi Matt,
Thank you for the offer, it's the bit that clamps to the bottom of the window glass. I've a feeling the yard might want you to buy the glass too which would be OTT.
Re: Window runner
Posted:
Fri May 11, 2012 11:04 pm
by Maphet
Well, I can at least find out. I'll get back to you on it when I know more.
Matt
Re: Window runner
Posted:
Sat May 12, 2012 12:06 am
by Moneypit
I took the old metro ones out of mine as they tended to cock up at one end and wedge.Used the ones out of an mgb roadster my neighbour was scrapping. Work a lot better. I presume you mean the bit thats also got the channel the rollers run in.I might still have them but I'm sure they had been cut into two short lengths for each door. I'll have a look tomorrow.
Re: Window runner
Posted:
Sat May 12, 2012 2:31 pm
by Maphet
Hey Rich,
While divorce proceedings are probably immanent, I had to visit the scrapyard today to pick up a new master cylinder and vacuum unit as mine suddenly developed the interesting fault of intermittently staying partially on after I took your foot off the brake. This was an interesting enough fault even for my beloved to accept. However, the upshot is that, in between playing Houdini with tourettes, I whipped out the driver's side runner from a G reg Metro Clubman. If you want to pm me a postal address, I'll pop it over to you.
Matt
Re: Window runner
Posted:
Sat May 12, 2012 8:46 pm
Maphet wrote:Hey Rich,
Matt
Hi Matt,
That's great thanks, I'll send you a PM.
Not sure what my foot was doing on your brake pedal mind...
