tyres tyres tyres
PostPosted: Sun Jun 14, 2015 10:21 am
by billybob
Hi all,
my car has midas wheels, the size is 165/60/13
it seems that they are nearly impossible to get hold of new....
is it safe to fit a 175/60/13? These are much more common but I am unsure of the implications.
Thanks!
Re: tyres tyres tyres
PostPosted: Sun Jun 14, 2015 11:44 am
by streetsy
My wheels are 13x5.5j I use 175/50/13 I have also used 175/60/13, both clear the arches with room to spare. The difference in diameter between the two is only about 12mm so won't have much effect on Speedo or gearing either.
PostPosted: Sun Jun 14, 2015 12:26 pm
by Mtrike
Also using 175 50 13 with no problem. These are available on line
PostPosted: Sun Jun 14, 2015 5:45 pm
by wolfie
I've used 185 55s before now but required a bit of grinding under the front arches by the wheel well to get full lock. 175 50s are good and a decent amount of choice
PostPosted: Sun Jun 14, 2015 8:08 pm
by Geoff Butcher
165 65 13 for me
PostPosted: Sun Jun 14, 2015 9:10 pm
by benofbrum
I have 165/65 13 on my Excelsior. When SVA'd the speedo was exactly right. According to a tyre chart I have from a Toyo brochure, both 165/60 and 185/50 are a smaller diameter and will over-read by about 2.5%. 175/60 is only fractionally smaller than 165/65
PostPosted: Mon Jun 15, 2015 8:43 am
by billybob
all very helpful,
it is great that the forum is so active....
I ended up going for 165/65/13 as this is what was in stock and is the same width as the back.. hasn't made an appreciable difference to the speedo according to the satnav- thought it might make it read a little low but I guess speedo accuracy wasn't amazing in the first place.
I think next time it needs new ones I will go for 175's.
the car is bonkers...never driven anything quite like it!
PostPosted: Mon Jun 15, 2015 11:26 pm
by kelvink
billybob wrote:the car is bonkers...never driven anything quite like it!
They are superb aren't they I love driving mine and I've driven some top notch cars including the Deronda many times and I used to own a Lotus Excel. It's no surprise that Gordon Murray rated it highly and that Lotus even took a look at the Midas too. At some point or other I may start to look at track day tyres but for road use the cars are simply amazing even on olde worlde 165s
