Brake lever refurb
My restoration of the Midas is nearly complete at the back end, all that is left are the brakes to finish. The handbrake cable recently arrived from Alistair and it was in the email exchange that took place that he mentioned wear in the handbrake levers being a problem.
I had a look at mine and they were indeed more than floppy with a couple of millimeters gap between the two parts after they came out of the acid bath. As I'm waiting for hydraulic cylinders to be delivered I took the grinder to the arms and removed the pivots. The resulting holes were then drilled out to 8mm and some stainless bushes were turned and pressed in with a little locktite for insurance, reducing the holes to 6mm.
The arms were ground flat and a 6mm stainless pin made to form the pivot pin.
A delrin washer was turned and drilled, this fits between the two sections, sorry about the poor photography.
The pin is retained with an 'E' clip over a stainless washer.
The finished assembly.
The levers now have a firm smooth action with no slop at all, rust shouldn't be an issue either and they should be virtually maintenance free. This is my first attempt with stainless steel, I don't know what grade I've got but its bloody hard and I'm going to need to go shopping for some decent tooling for the lathe if I keep on using it.
