This forum is for Midas and Midtec Bronze enthusiasts. The Midas is a British car designed as a replacement for the Mini Marcos. https://midasownersclub.co.uk/forums/
K series left hand engine mount looking from the wheel arch, i have no point of reference but it don't look too clever
Re: Does this look knackered to you?
Posted: Sat Oct 25, 2014 9:49 am
Just looked at the one on the GTM, the alloy section in the middle should be centralised between the rubbers, so no, yours doesn't look too clever.
Posted: Sat Oct 25, 2014 11:02 am
by Jin
Arse
Thanks mate Much appreciated
Posted: Sat Oct 25, 2014 6:46 pm
by b1zbaz
That's fooked
Posted: Sat Oct 25, 2014 9:34 pm
by Jin
Does explain 1 of the many clonking noises I hear on a daily basis
Anyone got a spare in any condition? Worse case scenario I can use it as a pattern
Posted: Mon Oct 27, 2014 12:46 am
by Jin
New mounts are rather rare and over a hundred quid !!!!
So until i get round to fabricating a new one I've bodged it by jacking it up and trashing a piece of hard 8mm thick rubber that's super glued to a piece of 3mm ally filed to a taper into the void, hopefully it will hold out.
Actually on some forums I've read regarding this recently this would be considered an upgrade?
