R1 into a mini
R1 into a mini
Postby manifold » Thu Jan 22, 2009 5:54 pm
An interesting perspective of an R1 fitted into a mini.
I think it speaks for itself. Perfect for a Midas...
Re: R1 into a mini
Postby Alan D. » Thu Jan 22, 2009 6:49 pm
Nice one David
It's chain drive,so not Promotive.
Any more information and the all important question for the new IVA test. Does it have a reverse?
Re: R1 into a mini
Postby manifold » Thu Jan 22, 2009 9:03 pm
Hi Alan,
Yes I think it's the Pro-motive one....
http://www.pro-motive.co.uk/Customerscars.html
Still very very nice though!!! And its real! The other one is still a pipe dream until I see it.
I am not sure what the situation is with reverse. The Z car one did it with a flywheel and starter motor. I think it could be done on the
Promotive one too if a flywheel was attached to the front sprocket.
Does the new test require a reverse. Does an existing Midas need to go through the test?? :) I would think it wouldnt.
Re: R1 into a mini
Postby Alan D. » Thu Jan 22, 2009 10:56 pm
Yes David,
You are correct. I'm getting it mixed up with the other one, where he designed and fitted a transfer box!
http://www.miniexvo.com/
Bit expensive,this kit!
Re: R1 into a mini
Postby manifold » Thu Jan 22, 2009 11:14 pm
yes it is a bit. maybe the credit crunch might make these a bit more realistically affordable!
Re: R1 into a mini
Postby johnnyfixit » Sat Aug 01, 2009 1:23 pm
or a different one to try ZX-9R photographed at Stoneleigh 09
either way the R1 looks more spacious
johnnyfixit
Return to Miscellaneous
