manifold wrote:.....or fabricate your own rings out of some reinforced grp.
Stuart wrote:manifold wrote:.....or fabricate your own rings out of some reinforced grp.
The rings are the easy bit, it's those 3 wire clips that'll be the tricky bit
There simply isn't room for the standard style retaining ring, if you went down that route you'd probably have to start off with that ring being mounted first and then everything else including the light its self being fitted from the back if that's possible.
wolfie wrote:JJC race and rally sell them. I've sifted through google searches and that's the only place I've found other than those already mentioned. I've searched under morette and cibie
