L_Jonez Mk2 rebuild
l_jonez
Re: L_Jonez Mk2 rebuild
Post by l_jonez »
Started taking another look at the fuel tank/pump set up...
Decided that the extra height from having the pump mounted on top of the tank would mean I'd have to space the tank down a fair bit which I'm not a fan of as I want to lower the rear end
Whilst looking through the scrap pile I spotted some 25mm angle so I fabricated a frame to recess the pump into the tank.
Just need to enlarge the hole in the tanks and weld it in.
l_jonez
Post by l_jonez »
Flange welded in
goldeneye
Post by goldeneye »
Looks nice!
Midas Mk II
l_jonez
Post by l_jonez »
Offered the tank up and it's fair to say I'm a happy man
I can get on with striping the old stone chip and paint off the tank and treating it to some por15.
Making/routing the fuel lines will be fun :-S
Won't the pump suffer from surge when the fuel level is low?
l_jonez
Post by l_jonez »
Should be ok nearly all cars run internal pumps with no problems.
l_jonez
Post by l_jonez »
Done a bit more today, rubbed down the other radius arm. Then both arms where treated to some por15 rust converter and given a few coats of red oxide. Being as the Mrs was out I took advantage and used the washing line to help speed up the drying
Later in the day came the satin black
Then out of interest I weighed the bits cut off the arms ( again being as the Mrs was out)
0.5kg not much but every little helps. :)
l_jonez
Post by l_jonez »
Have not updated for a while, I've done a bit in the frame....
Start of engine mounts
All 3 are done and they support the weight of the engine. I just need to tidy the up round corners etc
Engine in the bay is tight on the driver's side and I've had to relieve the headlight recess a bit which means I'll have to space the headlight forward a bit or look at a smaller option
Progress is slow but it feels like I'm getting somewhere now.
Post by Jin »
Great updates mate, good progress
l_jonez
Post by l_jonez »
Well today I went to castle comb and met a couple of the club members and it's spured me on to get this Midas finished and to actually join the club...
Hopefully some decent updates soon
