Update Friday 13 July 2018.
The last few months I have been making a lot of miles/km's. The last 700km's were without problems. At last! The problems I had:
Distributor failure.
I had installed a complete kit from Powerspark, new coil, leads and dizzy. The distributor failed after 200km, leaving me stranded by the road. I got a replacement magnetic module, but the car was difficult to start with it. Possibly the gap was too big, but Powerpark does not give gap value. In the end I reinstalled the Lucas 65D dizzy and it is performing very well. Earlier ignition problems were due to a coil with a 3 ohms resistance. When using an electronic dizzy, the coil should have a max. resistance of 1.5 ohms. Another lesson learned.
Steering wheel spacer.
An issue with the seating position of the Midas I have had with all my cars is a) correct leg position or b) correct arm position. Although the steering shaft on my car is already 1 inch longer than standard Metro (don't know from what car it came, mod by previous owner), but still I found the steering wheel to far away. So I bought this hub spacer, cheap and easy to install. My seating position is now perfect.
https://www.ebay.co.uk/itm/Schwarzes-Al ... 2749.l2649
Carburettor leaking and erratic behaviour.
I had a problem with the float and float needle, it seemed. I bought a new viton tipped needle but could not get it to seal. After lots of trouble shooting I found the return line of the fuel pressure regulator kinked, so max pressure was sent to the carburettor (in this case 1.5 bar with a pump running on 6V). The line was straigthened (it rests on the fuel tank, so difficult to see) and locked in place with a tiewrap. The fuel pressure is now 0.5 bar again and the carburettor is performing very consistent.
Vapour lock.
With the warm weather and slow touring speeds my engine was suffering from vapour lock. I removed the front undertray to give a bit more fresh air. Still not perfect but it works for the moment. The definitive solution would be a temp sensor controlled fan as has the MGF. Or if I dare, remove a strip, say 2cm from the bonnet rear edge so you get an air slot. Lots of negative pressure near the base of the front windscreen, my first Midas had it.
For the rest it's a joy driving this car, very fast but fuel efficient. I am doing around 3800rpm at 120km/h. Lambda values are around stochiometric, fuel consumption is 1:15 (42mpg) open top driving. Not bad for a tuned engine. Sounds amazing as well.
Summer is still the best ever, if I have a spare afternoon it's going for a spin. For the rest not much to do, just have to remove the bugs frequently!
