Micra engine in a Metro subframe
Looks interesting :o
metro micra.jpg (70.3 KiB) Viewed 49943 times
Re: Micra engine in a Metro subframe
good luck :)
manifold wrote:good luck :)
Thanks, I'll need it, it looks like it will be possible to squeeze it in under the bonnet, just 8-)
Post by DavidL »
So how much power/torque can you get out of one of those? How tunable(tuneable?) are they?
I'll be more than happy with more or less stock power to be honest.
Here's a very good read on some mods, that forum always runs really slowly with me for some reason
http://www.micra.org.uk/threads/40439-q ... by-EBBdude.
Post by DavidL »
Stuart wrote:I'll be more than happy with more or less stock power to be honest.
Thanks Stuart. Looks like the slow running isn't just you!
Jon Auty
Post by Jon Auty »
Ive managed to get a honda b20 in the front of a standard length round nosed mini van so im sure you'll make it fit! Looks alot smaller lump
Yes it's much smaller, the problem on the Midas is the sloping bonnet and the headlights that are set so far back, even David with his special A-series engines needs a higher bonnet.
Stuart wrote:Yes it's much smaller, the problem on the Midas is the sloping bonnet and the headlights that are set so far back, even David with his special A-series engines needs a higher bonnet.
I recall the chap in the Caribbean fitted a Nissan engine in a Bronze without any problems. Pics on the Yahoo forum.
Indeed, even has air-con by the look of it. That is an earlier and much smaller engine, with a much more compact gearbox that meant it could be pushed well over to the nearside.
Still it shows what can be squeezed into a MK 1 and MK 2
