Page 2 of 2
Re: Towbar
Posted: Fri Sep 02, 2011 9:15 pm
by DavidL
manifold wrote:[snip]
Like I said earlier, I was told it was a 'factory' one but the quality of build makes me doubt it. The actual design itself is fine though. I am always using the tow hitch. Great for moving tall ladders about on a trailer.
Looking at the photos I'd also doubt that it was a factory made item; it looks to me like it blocks off the three vents in the back panel. I can't see the factory doing it that way - as I understood it, those vents were to allow air to flow around and past the silencer. However, that could be a load of rubbish and they might just be "styling" vents.
Just about every vehicle I've ever owned with four wheels has ended up with a towbar attached, it's something I can't live without now. Might be something to do with being brought up driving tractors.
Re: Towbar
Posted: Fri Sep 02, 2011 9:24 pm
It doesn't block the back ports off.
However I do have a 'special' factory bumper which has 'hidden' vents under the rear lights to release the air pressure.
Not seen any others like them, although there must be.
Re: Towbar
Posted: Fri Sep 02, 2011 10:35 pm
by DavidL
manifold wrote:It doesn't block the back ports off.
My mistake, must be the way I was interpreting the photos.
However, do the "hidden" vents appear under the middle section of the rear light units? Mine has what look like vents there, they're about 2.5" - 3" wide and just big enough to get my four fingers in.
Re: Towbar
Posted: Sat Sep 03, 2011 3:07 pm
by DavidL
Just looked again, they're just wider than the reversing light lenses, and just below them. From directly above, the rear edge of the vent is just visible. Are those what you mentioned, David?
Re: Towbar
Posted: Sat Sep 03, 2011 6:23 pm
by Jon
David,
The rear bumper on my first '89 Gold had the top vents and foam filling, the GTM made replacement (which I think was the one you acquired from the guy in Rugby) was a thicker laminate with no foam or top vents.
As for the 'factory' provenance of the tow bar, the guy who sold me the car with it on said he was told that it was a factory fit, and I'm pretty sure that Dick Arbury who was the original owner of that car, which was Corby factory built, told me he had it fitted at the factory. I agree with you though, it didn't look very professional. We'll never know for sure, as Dick died about eight years ago.
Jon
Re: Towbar
Posted: Tue Jul 17, 2012 2:33 am
by DavidL
David,
I'm about to start building my towbar, but before I do; do you know (or can you measure!) the thickness of the steel used to make yours?
Thanks.
Re: Towbar
Posted: Tue Jul 17, 2012 10:03 am
Its generally about 4-5mm angle Iron and box section.
Re: Towbar
Posted: Tue Jul 17, 2012 11:04 pm
by DavidL
manifold wrote:Its generally about 4-5mm angle Iron and box section.
Thanks, David.
