wiper blades
Re: wiper blades
tankosl wrote:Hi All,
Thanks for all your responses.........
I think I'll have a look for some 14" flat blades then...........
Does the standard fitting kit have an option for the Mini arms????
Have a look at this link, shows a blade with a selection of adaptors. I'd think the bayonet type is probably in there somewhere, I wouldn't recognise it but I'm sure you could...
http://df2004.en.made-in-china.com/prod ... -901-.html
Alternatively, you could source a pair of Fiat 126 wiper arms. You might even have to do that to accommodate the longer blades. Not sure what fitting they take though, I haven't been out to the car recently...
tankosl
Re: wiper blades
Post by tankosl »
Hi all,
My car came without wiper arms and blades....... :(
The wheelboxes are mini from what I can tell, I've bought replacement mini arms that fit well, but I need to sort out a new set of blades............ :?
I hope this isn't going to be a problem.......
Re: wiper blades
Your wheelboxes will almost certainly be Mini, but I don't think the knurled end where the arms fit is specific to Minis; I think the original build manual is somewhere on the site, it will tell you which wiper arms to use. Just look for the build manual for a Mark 1 or Mark 2 (Bronze, Silver, or original Gold (not the Mark 3 which uses the Metro wiper system)).
tankosl
Re: wiper blades
Post by tankosl »
Thanks for the info.......
I've got the original build manual and I've seen nothing about the wiper arms/blades, but perhaps that means I need to look harder???? ;)
Re: wiper blades
tankosl wrote:Hi,
Not necessarily. I haven't read the Bronze build manual since 1985, I had assumed the info would be in there somewhere, but it may not be. Hopefully someone else might be able to give you a definitive answer!
(I'd already downloaded the Gold build manual but not the Mk 2 manual, which I can't access just now. The Gold's manual specifies using standard Metro wiper arms, with slight modification (bending the arms slightly) and using 14" blades. The Gold also uses the same Fiat screen as the Mk 1/2 but the position of the wiper spindles may be different, so the Metro arms may not work on the Mk 1/2.)
tankosl
Re: wiper blades
Post by tankosl »
I think I'll look out for some metro ones and have a play...........
Re: wiper blades
tankosl wrote:I think I'll look out for some metro ones and have a play...........
Metro ones won't work on mini spindles, Metro spindles have a thread on the end so the wiper arm is held captive by a nut.
Re: wiper blades
You're quite right, my apologies. I'd forgotten that.
Tankosl, I do hope you haven't already gone and spent money on a pair. If so, I apologise...
tankosl
Re: wiper blades
Post by tankosl »
No problem, I haven't bought any yet thanks.......
Howard
Re: wiper blades
Post by Howard »
I'm tinkering with wipers at the moment.
So far I've found LandRover Defender arms to be a good alternative. Britpart produce lots of cheapo goodies for Lannies & the arms come in both spline & bolt on varieties - they just need the bend at the end straightening out a little. They also do splined adapters, if you fancy getting "Blue Peter" with some scrapyard booty. 16, maybe 17, inch blades look to be the biggest you could get away with if you sort out the geometry.
I'm sure I've seen Fiat 126 wiper arms (on a Mini rack) recommended in a build manual somewhere.
Return to “Mk 1”
