Page 2 of 3
Re: BMW K series cylinder head conversion
Posted: Mon Feb 13, 2012 8:22 pm
by miniswift
Hi,
I think BMW uses inlet rubbers to carry injectors.
So, if you can make GSXR 600 to work, it might be OK.
I have about 5 different setups but one of them come with Injectors built in like GSXR600.
I think you need to find out what BMW cylinder head is like first. If it has injector holes in the cylinder head, you can use that for your injectors.
I don't know much about BMW cylinder head as I went full engine conversion instead.
You can have an air box for postage cost as I don't need them!
If you need flanges cut, send me gasket and I will get it laser cut for you in your choice of material.
Cheers
Atchi
Posted: Tue Feb 14, 2012 12:14 pm
by DavidL
manifold wrote:Yes its independent throttle bodies.
I have a couple of sets of ITBs I wont be using, complete with injectors from a GSXR600 which I am sure the right size for your needs. Open to reasonable offers. These can be respaced to suit any engine.
miniswift wrote:Hi,
Cheers
Atchi
Thanks, both of you.
However I think on this occasion I'll let it go, and keep my eyes open for a 16 valve head, I think that would be more fun... :D
Posted: Tue Feb 14, 2012 9:20 pm
by rocketron
Have seen a few times a mini with a BMW head conversion racing at Anglesey, and spoke to the owner/builder,driver at some length. Said the conversion had cost him £8 1/2 K so far. My friend who has built several minis for circuit and grasstrack racing thought it was a lot of money, especially when a 1380 A series beat it several times that weekend!
Posted: Tue Feb 14, 2012 10:16 pm
by DavidL
It's all somewhat academical to me just now, as I've not got anywhere near that much money to spend on it, more like £85 than £8500! My idea was to try and find a spare A+ engine so I'm not working on the only engine I have for the car, which is currently running OK anyway, and work on the spare engine as and when money and time are available.
On that subject, does anyone have a spare A+ engine they'd be willing to sell? I'm still kicking myself for giving one away for nothing, about 3 years ago - although that one was a bit of an oil burner...
Posted: Wed Feb 15, 2012 12:18 pm
I dont think it would cost 8.5k to knock up a BMW k engine. Especially if you undertake some of the work yourself. More like a grand or so.
K heads cost about - £2-300
Motorbike throttle bodies (if they dont come with the K head) £60-£100
Megasquirt - £200
Coil and edis bits - £40
Fuel pump bits - £100
SC exhaust manifold - £250 http://www.twinkam.co.uk/shop/article_S ... C002.RD%26 (or make your own)
A bit of alloy welding to plug up some holes and a head skim - £100
Force racing K head kit - £540 http://www.force-racing.co.uk/bmw-k-100 ... sion-kits/
Piston pocket machining - £50
Jackshaft - use existing cam or get an old one machined down on a lathe - £peanuts.
It all depends on how far you want to go with it. If you were needing to race it and want the best advantage you can get then you will need to put a steel bottom end in and a matching gearbox then yes you can get to these figures, but for a hobby car which goes on the road and is only booted now and again I'm sure a vanilla k head kit will do.
Posted: Wed Feb 15, 2012 4:09 pm
...talking of which, theres one on EBAY right now for £150 Buy it Now.
Bmw K100 (8 valve) Cylinder Head For Mini Conversion
With Specialist conponents Build Manual & Pump Drive
Complete head, cams, valves, fuel injectors, fuel rail, Throttle Bodies & air box.
http://www.ebay.co.uk/itm/Bmw-K100-Cyli ... 2c62fe4737
Posted: Wed Feb 15, 2012 10:16 pm
by DavidL
David, many thanks for taking the trouble of doing a ballpark costing, it's made me stop and think. I knew this wasn't a straightforward head swap, but when you look at all the work involved, I think I'll wait till I can get hold of a 16 valve head and work with that. Even if I were to get hold of a head now, I wouldn't be able to start working on it for a month or two...
manifold wrote:...talking of which, theres one on EBAY right now for £150 Buy it Now.
Is it not odd that there's no option to bid up to the BIN price?
I think I'm going to have to put this idea on hold for now. Our bathroom upgrade is costing more by the day, and sometimes you just have to be sensible with your money. I think I get more brownie points for spending it on wallpaper and cushion vinyl than on shiny oily engine parts...
Posted: Wed Feb 15, 2012 11:02 pm
No probs.
I think the break down I have given is pretty realistic to the costs involved for a K Head. Only thing I might have missed is a trigger wheel, but you can make one of them up with some tin snips and a bit of tin if push comes to shove.
The costs involved for a KAD headed engine are in a different ball game altogether if you want to do it properly.....mind you, the results are spectacular.
Posted: Thu Feb 16, 2012 11:30 am
by DavidL
manifold wrote:No probs.
I'd though of an empty cereal packet and a pair of nail clippers...
manifold wrote:The costs involved for a KAD headed engine are in a different ball game altogether if you want to do it properly.....mind you, the results are spectacular.
One day, I hope to persuade you to take me for a spin in your KAD headed Midas... :D
Posted: Sat Feb 18, 2012 10:33 am
Here's the Bingley Mini Marcos sporting the bulge
