This forum is for Midas and Midtec Bronze enthusiasts. The Midas is a British car designed as a replacement for the Mini Marcos. https://midasownersclub.co.uk/newforum/
What do you determine as cheap road tax mine is considerably more expensive than my focus cmax
Re: honda engine
Posted: Thu Mar 14, 2013 9:29 pm
£135 instead of £220.
Re: honda engine
Posted: Thu Mar 14, 2013 9:40 pm
by lankyjames
Stuart wrote:£135 instead of £220.
Thats a good point, what is the tip-over point? 1549cc, got to stick below that then as an engine choice, not that many over 1.6 would fit!
I'm still vying for a 1.5 Honda D series Vtec, one day!
It's got a much smaller valve/rocker cover than the B series and looks like it would fit with oodles of room....;
I think if money were no object however, this is the conversion I would like;
Re: honda engine
Posted: Thu Mar 14, 2013 9:46 pm
Yes it's 1549. The 1.5 D-series would be my choice if I didn't already have another engine. Some cars even have impressively high gearing that would suit 12" wheels really well, and of course lots of room to retain the master cylinders.
Although hopefully VED will done away with in he not too distant future.
Re: honda engine
Posted: Thu Mar 14, 2013 10:38 pm
by kelvink
That does look seriously interesting.
Re: honda engine
Posted: Fri Mar 15, 2013 7:04 am
by lankyjames
And all speed engineering are no more than 13 miles/32minutes from my home....one day.
And of course with nothing better to do on the morning commute, I've found a D15Z8 in Leicester which is good for 114bhp (according to wikipedia).
Power, cost, availability, reliability, lower tax bracket....why am I not yet doing this conversion?!
Re: honda engine
Posted: Fri Mar 15, 2013 8:41 am
From memory the car to get is the Civic 1.5i LS. that has the highest diff ratio. Never buy just an engine for a project like this, always buy a complete car.
Definitely buying a complete car is the way to go Stu, easier to use the new loom from the donor car and modify it over I think. Give yourself a new ignition, plugs into the dashboard speedo and ECU easy business.
The 1.5i LS is around 99bhp, which is plenty in a Midas and thats before engine mods of course, as I understand that's without vtec?
Re: honda engine
Posted: Fri Mar 15, 2013 12:53 pm
It has 114 hp, and a very good 24.3 per thousand 5th gear on the standard 14" wheels.
I can't remember now, I do remember some cars were described VTEC and others not, but they all had the same power. The 1.5 from the CRX imports is around 130 hp, I forget the engine designation. When you start looking into Honda stuff you realise what a bewildering array of engine variations they produced.
