Only if you've got 8.4" discs on. The one I've seen on tens looked fine, and the rolling diameter on the 10" is about the same as 12"goldeneye wrote:are 10" wheels not to small for a Midas?
Decathlon coming alive
Re: Decathlon coming alive
They possibly are but I'm running 7.5 brakes off a 1275 gt so have the option should I want to try it and if I go low then they will fit great
Well it's more than alive its going Stanford hall next week too so be sure to look out for me on the gr8 minis stand although there are cosmetic bits to finish like carpets and door seals but it's road legal and that's what matters
https://flic.kr/p/Lp7sC7
I've booked a Midas OC stand if you would like to.join us.
Cheers folks I will be there at Stanford hall but will be with the gr8 mini team as they helped build and finish off the Midas plus the wife and daughter will be in her mini so ideally need to park with her. But rest assured I will come over and say hello
