Front suspension, need to drain the suspension?
- minisweden
Re: Front suspension, need to drain the suspension?
I´ll have a go at it tomorrow. Did not get around to it this evening. I´ll let you know how it turned out. would like to loose the Hydragas units though, saw a thread about coil springs. Are there any kits available that are "plug and play"?
minisweden wrote:I´ll have a go at it tomorrow. Did not get around to it this evening. I´ll let you know how it turned out. would like to loose the Hydragas units though, saw a thread about coil springs. Are there any kits available that are "plug and play"?
Not really, the only stuff I've found has to be adapted from a Mini base. That said as soon as I have milling facilities I'll be adding to the thread with a bolt on option.
- minisweden
Rich wrote:Not really, the only stuff I've found has to be adapted from a Mini base. That said as soon as I have milling facilities I'll be adding to the thread with a bolt on option.
Great! When you are ready, I´ll be one ofthe first customers
- minisweden
Sorted! Managed to slip the suspension and get the driveshaft out. Looks like just the seal, got plenty of them for the Mini I guess they are the same. My problem was that it needed quite some heaving to get the lower ar down enough. I put a crowbar between the subframe and the anti roll bar and really applyded some force. That did the trick.
