Something I have been working on.....
Re: Something I have been working on.....
Hi Jim,
Carl already does them rose jointed for the mini, albeit you would need to mount them to a simple beam. Pretty easy to make though for the midas.... straight box section with some ears on for the rose joint mounts.
Geoff Butcher wrote:I think this car has evolved into a new species!
;) its going that way isnt it Geoff.
Main thing is that, except for the slight cut out for cam pulley and different bonnet, I haven't actually modified the body in any other way. That is the driving force for my ideas, to touch the body as little as possible as I still believe the car silloutte is as up to date as anything on the market now. The running gear is obviously a different story.
When looked at side on compared to the latest Nissan skyliner replacement, taking the headlamp caps away and its more or less the same lines, albeit shruken down.
Its my pocket battleship LOL.
update:
Very nice, now you need a transparent body to show them off 8-)
gooseman
Post by gooseman »
NICE PIECES!!! They would even be nice in mild steel.....maybe ill get around to it one day....i can see them in square tube also...great pics david
No probs Jim.
If you want any dimensions let me know.
Eg, Using 1/2inch UNF for shock pickups and 3/8 rose joints .
here you go Hans.
Sorry it was a bit dark but maybe you can do something with it with photoshop.
Ignore ride heights. I haven't set the suspension or put the motor back in yet.
Hi David,
Can you PM me the biggest possible files of these pics? The ones on the forum are too small to work on. I need pics of a few MB to be able to zoom in on the lights without losing too much resolution.
Cheers, Hans
If you would paint them white the light covers would more or less like this:
David lightswhitesmall.jpg (46.5 KiB) Viewed 6868 times
looks great that Hans!
Looks pretty darn modern to me ;)
Return to “General Chat”
