rear coilover brackets for midas gold
Re: rear coilover brackets for midas gold
No disrespect to those who like cross dressing but theres no way I am putting a skirt on my car. :shock:
One of the guys over on Turbo Minis has a group buy on Protech dampers/coilovers going, might be worth a look........
Post by b1zbaz »
how do you put photos on
Create an account in Photobucket (www.photobucket.com) and upload pictures there. There is a link function in photobucket which you can click which auto copies it for you. Then you click and paste in your message and your link should appear. It should start in "" and end in "".
Post by b1zbaz »
the group buy on turbo minis will they be the same as mine or different
b1zbaz wrote:the group buy on turbo minis will they be the same as mine or different
If they include springs, and they're for fitting to a standard Mini, then the spring rate will probably be too high for a Midas.
(edit) That applies to the rears. Fronts, I think, would be about the same rating.
Someone more up-to-date care to comment?
You pick the dampers/coil overs from the Protech site, the springs are extra so you use whatever you want.
