Re: rear coilover brackets for midas gold
Posted: Thu Mar 31, 2011 1:08 pm
No disrespect to those who like cross dressing but theres no way I am putting a skirt on my car.
This forum is for Midas and Midtec Bronze enthusiasts. The Midas is a British car designed as a replacement for the Mini Marcos.
https://midasownersclub.co.uk/newforum/
If they include springs, and they're for fitting to a standard Mini, then the spring rate will probably be too high for a Midas.b1zbaz wrote:the group buy on turbo minis will they be the same as mine or different
You pick the dampers/coil overs from the Protech site, the springs are extra so you use whatever you want.faceofdoh wrote:If they include springs, and they're for fitting to a standard Mini, then the spring rate will probably be too high for a Midas.b1zbaz wrote:the group buy on turbo minis will they be the same as mine or different
(edit) That applies to the rears. Fronts, I think, would be about the same rating.
Someone more up-to-date care to comment?
