Page 3 of 3
Re: BMW K series cylinder head conversion
Posted: Sat Feb 18, 2012 11:11 am
by DavidL
Thanks for reminding me, A111...
...paging David Manifold! Would a BMW headed A series...
(a) fit under one of your modified bonnets?
(b) be taller or shorter than a KAD engine?
(c) and where does the 7 port engine come in terms of overall height?
Posted: Sat Feb 18, 2012 12:36 pm
Hello David.
Ok. Looking at the dimensions I reckon a k head will definitely fit under one of my bonnets. The head is narrower than the Kad head and the pulleys look smaller. Looking at the marcos it looks shorter too. I fitted a long cam kad head under mine though which is bigger than my new short cam kad head. Worse case scenario is a slight bulge on the offside for the cam pulleys.....like the mk4 has on its bonnet, but I think you would probably get away with it.
The bonnet was designed by me to fit over a 7 port head with twin carbs anyway...so you are good to go on that one.
A 7 port head will not fit under a standard bonnet.
I have the moulds for the cross flow bonnet if you need one.
Posted: Sat Feb 18, 2012 1:44 pm
by DavidL
manifold wrote:I have the moulds for the cross flow bonnet if you need one.
I know, I hope to be in a position to ask you if I can borrow them at some point! :)
Posted: Sat Feb 18, 2012 2:33 pm
I probably won't be lending the moulds out for fear of them getting scrapped with a bad release (easily done!) however I would be happy to make you a bonnet when your ready.
Posted: Sat Feb 18, 2012 7:14 pm
by DavidL
manifold wrote:I probably won't be lending the moulds out for fear of them getting scrapped with a bad release (easily done!) however I would be happy to make you a bonnet when your ready.
I appreciate your reticence, I'd probably feel the same way.
Just noticed this http://www.ebay.co.uk/itm/ws/eBayISAPI. ... NA:GB:1123 on eBay.
I'd be bidding if I knew anyone who could collect it for me. Two hours to go, and so far, it's only reached £26...
Posted: Fri Feb 24, 2012 10:45 pm
Here's an interesting article about the K-head conversion:
http://www.dep-o.co.uk/2011/04/ultimate-a-series/
Posted: Sat Feb 25, 2012 3:47 am
by DavidL
Hans Efde wrote:Here's an interesting article about the K-head conversion:
Thanks, reminding me that maybe an 8 valve conversion might be worth considering over the 16 valve, to get more power lower down the rev range. Decisions, decisions...
