Page 3 of 3
Re: Coil spring rates
Posted: Wed Oct 28, 2009 12:02 pm
Alan D. wrote:Hello again,
My preferred option would be: A vertical rod attached to the top arm shocker position, transferring the load vertically to a bell-crank. The bell-crank would be pivoted at Hydra-gas mount (some how). The bell-crank would be a 90 degree one. which would transfer the suspension loads to a coilover mounted horizontally across the back of the subframe, with all loads being transferred into the subframe. A Midas with inboard suspension!
Hi Alan,
Scroll down the linked page
http://www.potenza.cc/assets/s2dmain.ht ... 8c708.html, looks similar to what you described, though on a Mini frame.
Posted: Wed Oct 28, 2009 8:32 pm
looks good to me
Posted: Wed Oct 28, 2009 8:43 pm
manifold wrote:looks good to me
It's certainly impressive, but I don't think it would work with a rear mounting exhaust unfortunately.
Posted: Wed Oct 28, 2009 11:32 pm
by Alan D.
Hi Rich,
Yes, that is just the sort of thing I had in mind. I just cannot work out the linkage on that example, i.e. how he transfers the suspension movement to the inboard shocker. Are there any more pictures?
I also like his treatment of the bottom arm!
I'm gathering components to make this tube bender at the moment (
http://www.gottrikes.com/Tube_Bender.htm )
I have the plans, the flat pieces of steel are now getting cut and I have now received the fancy air/hydraulic ram from the USA. So if I ever get finished doing property renovations. I should be able to tackle bottom arms like that and also, things like extending the roll cage to the screen, to try and eliminate the scuttle shake!
Posted: Thu Oct 29, 2009 11:29 pm
by johnnyfixit
Z cars use this type of linkage surley (and don't call me shirley) this could be a different way around the other way
looks a lot less work than
and is more adjustable axis wise
Posted: Thu Oct 29, 2009 11:45 pm
I'm liking that Johnny, I'd love to have the wherewithall to come up with something like that.
Posted: Fri Oct 30, 2009 12:11 am
yes its on ebay that one right now.......
