As I walked into the garage today I knew it was time. I could put it off no longer. The master cylinders had to come out. To anyone who doesn't know Minis that well, that means putting your head under the pedals, your feet where the back seats should be and using a pair of needle nose pliers to get to 2 split pins out of the most inaccessible place on the car. Or something like that anyway. So having given the heater panels and washer bottle bracket another spray of hammerite, I set about the horrible task that awaited my feeble skills.
It took about 4 minutes, one of which was contorting myself into position then realising my screwdriver was still on the workbench. The master cylinders were held in with "R" clips. All I had to do was push them out using the flat end of a screwdriver and then move the pins so they came out. I want to buy the man who put them in a beer! The master cylinders themselves need a refurb (no surprise there!) so I will have to put that on the Xmas list. Times is hard!!
I then set about removing the rest of the stuff in the engine bay that I could. This meant all bolts, brackets and heatsheilding. My Dremel went through 9 cutting discs going through all the rusty bolts that wouldn't budge, which was nearly all of them. The bonnet release cable and bracket was a particular pain as although I was able to undo the bulkhead bolts without any issues by jamming a spanner on the nuts inside the car, the bolts holding on the lever beneath the dashboard shelf were so rusty and inaccessible that cutting was the only option. It still took 15 minutes as I couldn't get the Dremel at the right angle due to the windscreen. I did annoy 2 earwigs which were living behind the bracket. They had to find new homes...
The heatshielding appeared to be a piece of carpet-like substance which had been siliconed to the bulkhead. This of course took ages to get off and had a collection of dead leaves and insects underneath. Tasty. The exhaust had obviously had an effect on the bulkhead in the past due to the scorched fibreglass I found. I will sand that out and build it back up before I figure out what sort of heatshield to use.
All the brackets are now off and only the pedal box and shock mounts remain until I can get the subframe off to attend to the brake and fuel lines. Could be a long time...
I love the man that put these in
Master cylinders out (and needing a refurb!)
Bracket held on by horrible silicone. What's wrong with a damn gasket?!
Horrible stuff behind the heatshield...
...which was also held on with bloomin' silicone!!
Burnt bulkhead
The collection of brackets and bars that came off. All need a clean-up and repaint.
All the stuff for the bin. There's a lot of bolts which have been cut in half...
The engine bay is almost completely clear!!!
