Page 6 of 6
Re: MED engine detune and overhaul
Posted: Sun Apr 28, 2013 8:50 pm
Glad your enjoying the benefits of the Watson Springs Conversion Hans. Its great isnt it. A lot more progressive than the Hydrogas. No more Hydrogas pumps to mess with too!
Posted: Fri May 03, 2013 1:48 pm
Posted: Mon May 06, 2013 1:49 pm
Just had a run with a tomtom on board and a thinner needle (ground BBW). Speedo is only 2 or 3 km/h lower than the GPS, so completely acceptable. 4000rpm is 120km/h, I'd prefer a slightly lower rev for cruising, but for driveability this 3.105 diff is the best. Engine pulls nicely in all gears. I love the low end torque and gradual build up of the power. Much better than the turbo which had nothing below 3000rpm and a punch in the face above it. Thinner needle gives already better AFR readings, but in the middle still above 13. I'll grind a bit of the middle section of the needle and tomorrow give it another go.
