Page 6 of 6
Re: F529YNG -LIVE (ON A KNIFE EDGE)
Posted: Sun Sep 05, 2010 11:58 pm
Good stuff! I hope it works out for you. For 30 quid or so it might be worth giving the head a quick skim...plus it will up your compression ratio a touch :).
Make sure block surface is smooth too! I hope you dont need to skim that as well...as it will be a right ball ache.
Posted: Mon Sep 06, 2010 9:27 am
by johnnyfixit
Compleated a compression test on all the cylinders
4= 200 psi
3=195 psi
2=200 psi
1= 200psi
can't find anything in the manual to compare these figuers to???
anyway one hell of a difference between the gasget I fitted and the payen bk 450 have a look
definatley looks stronger between the bores
