Page 7 of 12
Re: L_Jonez Mk2 rebuild
Posted: Fri Mar 11, 2016 8:19 pm
by l_jonez
Cheers guys.
I'm hoping for a pretty decent final finish. Sadly spare time is very limited so progress is slow.
Posted: Fri Mar 11, 2016 9:01 pm
by Geoff Butcher
Rich wrote:The underside of your car looks better than the topside of mine.
And mine!
Posted: Thu Mar 31, 2016 8:28 pm
by l_jonez
Well I've not had chance to do anything on the Midas other than turn it over and preped a small area but I'm sooooo bored of sanding etc now
However I have started collecting more turbo parts, hopefully a new Toyota inlet manifold ( to mate with the micra one) and a small VW intercooler will be with me shortly
Just need to get this underside finished and I can move on to the fun stuff
Posted: Mon Apr 04, 2016 6:59 pm
by l_jonez
Intercooler turned up today
The plan is to fit it at the front behind an unused cold air feed, although I'll probably enlarge it to get more air through.
It will be rotated so that the tanks are top and bottom when it does get installed to give better pipe routing
Also it will mounted further forward.
Posted: Wed Apr 06, 2016 10:17 am
by trevor d
Good luck with the rebuild i am starting mine soon hopefully
Posted: Thu May 19, 2016 9:19 pm
by l_jonez
After what seems like forever the other half of the floor is ready for stone chip
Also Ive cut out the fresh air duct to a more suitable size to allow air to the inter cooler
Posted: Sat May 21, 2016 8:28 pm
by l_jonez
Well that's the floor pan finished
Only 99.8% of the project left
Posted: Sun May 22, 2016 8:42 pm
by l_jonez
Well the Midas is finally the right way around again
The paint has been removed from the rear beam and it fitted back on to the car, all be it temporarily as I have to fit brake and fuel lines at some point.
Posted: Sun May 22, 2016 9:32 pm
by kelvink
The galvanizing has done an excellent job there. I may well have to look into getting mine done as it makes so much sense really given these cars can last the test of time rather well by all accounts. It's excellent seeing so many people spending time and money restoring them
Posted: Sun May 22, 2016 9:39 pm
by l_jonez
Yep it's like new, mind you the beam has never seen the road although I have no doubt it will stand up well.
