The rev counter I now have has no needle on it. I figured I could easily fix it by removing the speedo needle from the clocks I already have. SO out came my gentle plastic trim removal tools and I started gently persuading it out. It was very tight and very stubborn. Eventually, it gave up and let go. Or so I thought. Nope, it had snapped the little prong that the needle sits on. Great.
I managed to get the prong out of the needle with some gentle work with some needle nose pliers, then set about putting it on to the rev counter. And I ran into yet another issue. At some stage Austin / Austin Rover / The Rover Group or whatever they were called that week had changed their design oh so slightly. The outside diameter of the old-style needle? 3mm. The diameter of the hole it had to go into in the newer-style clocks? Yup, 2mm. I thought I would be clever and gently file it down using a needle file (geddit?!). Did this work? Nope. All it did was collapsed the plastic so now I can't use it at all. It was at this point that I shut the garage door and walked away.
Anyone got a 90s Cooper-style rev counter going cheap?
Rev counter came without a needle
So I thought I would be clever, and use the needle from my other speedo. Instead I broke bits and got frustrated.
