Page 8 of 9
Re: Rear Disc conversions
Posted: Tue Dec 11, 2012 10:36 am
by DavidL
b1zbaz wrote:Would rear discs not make the Midas prone to swapping ends with mine tries doing it now occasionally when it's icy or slightly damp
It shouldn't if the operating pressure is reduced enough.
I presume you do have a pressure reduction valve of some sort on yours? Sounds like there's too much pressure going to the rear brakes and they're locking up before the fronts.
Posted: Mon Dec 24, 2012 10:26 am
by Alan D.
Posted: Mon Dec 24, 2012 10:43 am
Alan.
My adapter plates for the Kad calipers have a circular hole to fit over the stub outer rim. The 3 bolt holes on the radius arm then bolt the plates to the arm. Counter sunk in the front face of plate with nuts on back. Very solid.
I hope that helps. Will try and do you some pics sometime if you want of the plates.
Posted: Mon Dec 24, 2012 10:47 am
by Alan D.
manifold wrote:Alan.
Hi David,
I'd had exactly the same thoughts. I wish I'd checked them before I got the laser cutting done, as they were quite expensive in stainless.
Posted: Mon Dec 24, 2012 10:52 am
These KAD plates are ally too. So maybe you could do a some practice ones in ally before going to stainless.
Maybe no need to go Stainless....and they dissipate heat better I would guess.
Posted: Mon Dec 24, 2012 1:11 pm
Here's a KAD one.
Posted: Mon Dec 24, 2012 3:51 pm
Cheers Stuart. Saved me getting the camera out. Those disks are different to mine too!
Posted: Mon Dec 24, 2012 3:57 pm
Yes they're a bit different as you say David
Alan is that your MK 3 Convertible in one of the photos ?
Posted: Mon Dec 24, 2012 6:42 pm
by Alan D.
[quote]Alan is that your MK 3 Convertible in one of the photos ? [quote]
Yes Stuart, I have three altogether now. Hopefully there will be some rationalisation, in the coming year. I just want to end up with one K-series convertible. that one in the picture is another A-series.
Posted: Mon Dec 24, 2012 10:13 pm
by DavidL
Alan D. wrote:Alan is that your MK 3 Convertible in one of the photos ?
Alan, please stop tempting me!
Despite me having said I don't want a Midas convertible, I am notoriously fickle...
